Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-14-2007, 03:34 PM
goon13642 goon13642 is offline
Jeep engine problem
I have a 1991 Jeep wrangler that I recently blew a rod through the engine block, I recently bought a 1991 engine for the jeep, but the engine is automatic. My jeep has a standard engine. I want to make the automatic engine work. the pilot bearing in the standard engine does not fit into the automatic engine because they were not made to be converted. I believe that it is possible. Anyone have any ideas?
Old 07-15-2007, 10:54 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Jeep engine problem
ok, the engines will be the same. the transmission is the part that is either automatic or manual(standard).
what has been done so far? is the old engine out of the jeep? is the transmission still in the jeep?
in a nutshell, you want to swap ONLY the engine, that means that stuff like the flywheel and bell housing from the manual trans will need to be kept(they are different )
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
