Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-14-2007, 12:29 PM
donalda4163 donalda4163 is offline
Unhappy 98 cutlass fuel pump
my 98 cutlass looses power ocassionaly, usually when the fuel tank is lowand you are going up a grade. The dealership has done fuel pressure checks and come up with nothing. They suggested replacing the fuel pump, said maybe the fuel strainer (sock) was some what plugged. They also said the strainer itself could not be replaced (had to replace the entire unit).
Does anyone know about this? or how to remove the fuel pump to check the strainer? Do you need to drop the tank?
Thanks
Old 07-14-2007, 02:58 PM
maxwedge maxwedge is offline
A990 racer
Re: 98 cutlass fuel pump
Tank must come out, the symptoms do point to either problem, but I believe the strainer is a seperate item.
