Old 07-14-2007, 04:17 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Kawasaki Ninja ZX-RR 2006
My 1st build in quite a while, I started off painting the panels with Zero Paints Mica Lime green over Zero Primer.
I have done work on the engine etc, just need to take so photos and upload soon.
Steve a.k.a. Hiroboy
Old 07-14-2007, 04:35 AM
Hiroboy's Avatar
Re: Kawasaki Ninja ZX-RR 2006
A few more photos now
Old 07-14-2007, 05:51 AM
Ole_L Ole_L is offline
Great start Steve... I have this kit and the Zero paint already, but want to finish the two Honda's first.
What CF did you use?
Old 07-14-2007, 06:34 AM
Hiroboy's Avatar
I used Studio 27's ST27-FP0004 Carbon Fibre Decal A Metallic Gray (Large)
Just liked the look of the weave, something different
Old 07-14-2007, 10:31 AM
ketje's Avatar
ketje ketje is offline
Nice start Steve.
How about the fit of the parts? Any problems so far?
By the way, your service is excellent. I'll be thinking off you for my next orders.
Old 07-14-2007, 11:04 AM
stevenoble's Avatar
Looks great so far Steve.Is the green you have used on the body parts metallic or not? It doesn't look so in the photographs but it does on your website.
Steve Noble
Old 07-14-2007, 12:25 PM
Hiroboy's Avatar
It's a very fine Mica Pearl which will pop when the clear is added, I was adding the decals and the Micro Sol was showing the pearl affect when wet
Old 07-14-2007, 02:44 PM
patoffspyder patoffspyder is offline
Looks great, I will add this color to my next order for sure :-)
Old 07-15-2007, 06:24 AM
ace91 ace91 is offline
wow, very good work, steve. your cf work is good.
i've just started this after away from modelling for 2-3 months. it's so nice to be back again.
adrian
Old 07-15-2007, 06:25 AM
So you add the decals onto a flat surface? Normally that would cause them to silver and really not adhere well because of the textured surface of flat paints. I'm asking because I'm close to the same stage on my Honda's and were going for clear - decals - clear to give the decals a better surface. You never had problems with decals on flat surfaces?
Old 07-15-2007, 11:33 AM
Hiroboy's Avatar
I'm nearly finishes adding all the decals, so i'll clear coat over the top in a day or two and what happens, in the past yes I have cleared, decaled and cleared again, but this is a quick build, I want to finish it soon and get back to working 18 hours a day.
Old 07-16-2007, 12:46 PM
Hiroboy's Avatar
More done
Old 07-16-2007, 12:53 PM
Awesome work!
stevenoble's Avatar
Looking really good.You sure work fast Steve.I like the look of the exhausts,nice heat staining effect.
Steve Noble
Old 07-16-2007, 03:07 PM
ravenpower ravenpower is offline
Hi, Steve
are you sure about the green paint, I have seen a lot of photos of the real bike and it seems to be a solid green, not pearl.Also the dedicated Tamiya spray can seems to be solid also.
How you have got the reference for the paint?Are you sure about that?
I know that sometimes photos can mismatch the real color, for example Rossi's NSR 2001 Nastro Azzurro yellow seems to be a solid yellow but I have seen it on the pit lane and I can tell you for sure that is a pearl yellow.
Thanks
