Old 07-13-2007, 05:55 PM
3KSL95's Avatar
3KSL95 3KSL95 is offline
Send a message via AIM to 3KSL95
Cost of clutch slave and master cylinder replacement?
Anyone have a quote on the replacement cost because my mechanic wants $618 and that sounds a little insane to me.
1995 3000GT SL (RED)
My mods:
Custom true dual exhaust with x pipe
K&N FIPK
17 inch forged aluminum billet rims from WELD EVO
Old 07-13-2007, 07:40 PM
sLADe781 sLADe781 is offline
Re: Cost of clutch slave and master cylinder replacement?
I hear shops do charge an arm and a leg for the work...mainly because the master's a b*tch to get to. At any rate, I say you do it yourself as it's not too bad of a job:
Master: http://www.3si.org/forum/showthread....er+replacement
Slave:
http://www.penguinhosting.net/~bigma...ecylinder.html
And if you wanted OEM parts, PM jason_bet or check out his website: www.pricematchedparts.com
Good luck!
Old 07-13-2007, 08:48 PM
X2Xtreme360 X2Xtreme360 is offline
618!?!? I am SOO glad I do the work myself cause I had no idea.
Go to autozone, buy master and slave rebuild kit for $20 a peice. Follow the steps on how to remove the cylinders (It's really easy I promise, as long as you know how to use a wrench.) And rebuild the cylinders (Once again... really easy to do, almost impossible to get wrong, just put the new parts in the same way you took the old ones out.) Basically if the cylinders are leaking, its due to worn gaskets, thats really all the rebuild kit is. It contains a new plunger and spring and maybe a screw or two... but once again, not hard to do.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 07-13-2007, 09:19 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
5.99 + shipping (should be next to nothing to ship) for rebuild kit or a reman slave for 17.99+shipping
Old 07-14-2007, 10:59 AM
3KSL95's Avatar
Thanks a lot guys i appreciate it. Im on my way to get the rebuild kit ill keep you posted.
My mods:
K&N FIPK
Old 07-14-2007, 12:05 PM
new2mitsu new2mitsu is offline
i bought a new Master and a Refurbbed slave 60 NEW for the master and 21 for the slave. not bad at all, my mechanic was gonna charge me almost 200 for the parts alone, i paid 80
