Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-13-2007, 02:16 PM
OC Dave OC Dave is offline
Arrow 92 cutlass ciera groaning in left front when turning left
I'm trying to figure out what is making the noise on my ciera. When I'm driving straight or turning right there is no noise or vibration, it only happens when I turn the wheel left of center I start hearing a groaning noise. Power steering fluid is topped off, tires are very good. I'm thinking it could be the wheel hub assembly bearing going bad or could it be the cv joint. The car makes no clunking noises so I'm leaning more towards the bearing starting to fail. Help !!
Old 07-13-2007, 03:00 PM
maxwedge maxwedge is offline
A990 racer
Re: 92 cutlass ciera groaning in left front when turning left
Welcome to AF, sounds like the bearing, try seeing if that wheel has any play in the hub when off the ground
Old 07-14-2007, 08:26 AM
Arrow Re: 92 cutlass ciera groaning in left front when turning left
I jacked the car up and there isn't any play in the hub that I can feel when moving the tire side to side and up and down.
Old 07-14-2007, 02:59 PM
A990 racer
It could still be the bearing.
Old 07-14-2007, 11:55 PM
I bought a wheel hub assembly and I'll let you no what happens. Thanks for your help and insight MaxWedge.
