Old 07-13-2007, 08:35 AM
redhot94stealth redhot94stealth is offline
clutch master cylinder removal
can someone please tell me how the hell you take off the clutch master cylinder please tell me
Old 07-13-2007, 03:47 PM
X2Xtreme360 X2Xtreme360 is offline
Re: clutch reservoir removal
Actually it's quite simple. Siphon the fluid out. The hardest part is removing the hard line if its never been removed before. I've heard of using a crescent wrench to get it. After that's done, get on your back in the driver side. Attached a little above the clutch pedal is a rod. The other end goes inside a rubber boot towards the firewall (thats the master cylinder) On the side attached to the pedal, remove the codder pin holding the bolt in, (the bolt attaches the rod to the pedal side) slide the bolt out. It takes a little fiddling to get it out of the way but it's not hard. Then the cylinder is attached with 2 10mm bolts from the inside of the car on the firewall. It's a tight fit, but takes a whole 10 minutes to do.
Look at the photo in the manual and its a little easier to understand, but those are the steps.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 07-13-2007, 05:37 PM
thanks man i really appreciate it
Old 07-13-2007, 07:41 PM
sLADe781 sLADe781 is offline
http://www.3si.org/forum/showthread....er+replacement
