Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-12-2007, 08:45 PM
'93mitsu2.0L '93mitsu2.0L is offline
Question MPI fuse Keeps Blowing
hi folks, this is first post, I NEED HELP.....
i own 93 mitsu eclipseGS 2.0L nonturbo manual trans, the car stmmble on second gear turn off and didnt want to start up, i had no fire comming out of the spugs, so i check aroung and found that the MPI fuse was blown, i replaced it and the car started right up , BUT now when i start to take off, as im
disengaging the clutch the car start to jerk and the fuse blows , everytime.
i can go on reverse and it drive well (on jerking) i can go on real low RPMS and it wont blow the fuse or jerk but when the RPMs go over 1500 or so the jerking strat and the fuse blow.
i've been working on it for 2 days im stuck can anyone help Please thanks
Old 07-13-2007, 10:39 AM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
Re: MPI fuse Keeps Blowing
Try looking at ALL of the wiring that goes into the fusebox. You could have a small but sensitive short in there which could be causeing your fuse to blow when voltage reaches a certain measure.
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
