Old 07-12-2007, 07:48 PM
Mar424 Mar424 is offline
1994 Honda Accord speed sensor
I think the speed sensor in my car needs to be replaceed. The speedometer jumps from 0-120 all the time and the check engine comes on and gives the code for the speed sensor.
So my question is, first, where is the speed sensor on the car? I have the haynes book and it says it is right next to the distributor, but it is not there on my car.
Also, whats the difference in speed sensors, on ebay they range from about $20-$200. Are there better brands I should get? Or some I should stay away from?
Old 07-13-2007, 07:15 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 1994 Honda Accord speed sensor
1994 Honda Accord Vehicle Speed Sensor (VSS) Location
Honda Accord Speedometer Jumping
That's where it is...I'm about to go look on my '95 and see...you didn't say auto or manual...it may be different but I don't think so...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 07-13-2007, 07:27 AM
Well hell...you're right, just looked on mine, it's not there (or anywhere near there) Looking from the top, I don't see anything that could be it either.
I'll try to find out something...
...empty gun rack.
Old 07-13-2007, 07:35 AM
OK I did find this:
That would put it in the output side of the diff, just above and inboard of where the passenger side CV shaft comes outta the diff...wife just left with the car so I can't verify...
...empty gun rack.
Old 07-13-2007, 08:51 AM
She came back and I took a look...really needed a flashlight but I think I do see it...right where the above diagram shows...in the output side of the diff...look at your thermostat housing. Now look at the space where the hose coming from it bends and goes forward...look down through that space where the hose bends and just rearward and inboard of that, it's right there in the transx casting...will probably have to relocate a few things to have room to access it, unless there's a tricky way to reach under some stuff...
...empty gun rack.
Old 07-13-2007, 09:05 AM
You know what? I think the first diagram does actually show the location...but you are supposed to assume the rest of the motor is "ghosted"...so it would actually be behind and to the rear of the distributor and head, which it is...it's a stupid drawing, makes it appear to be in the top over the flywheel, next to the distributor...
Mystery solved!
...empty gun rack.
Old 07-13-2007, 01:09 PM
Mystery solved!
yes, mystery solved!!
thankyou, i now know where it is, nows just the fun part of trying to get to it
