Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-12-2007, 12:51 PM
sol147 sol147 is offline
Battery Drain
My battery will slowly drain while car is not in use. I traced the batt drain to a fuse on the fuse panel labeld LID a 15 amp fuse. Does anyone have any idea what the LID fuse is. Our local chevy dealer maintenance department doesn't know.
Sol147
Old 07-12-2007, 06:59 PM
Nicholass1979 Nicholass1979 is offline
Re: Battery Drain
I have a 94 firebird and the battery drains when I leave it in storage for the winter, so far my solution has been to just pull off a battery cable. I just figured that something maybe to do with the remote door unlockers is drawing a constant charge and over enough time would drain the battery
Old 07-12-2007, 09:59 PM
mc_nish73 mc_nish73 is offline
Re: Battery Drain
Battery drain over time is normal. Any vehicle with a computer, stereo system, or any electrical component in it that has a memory needs constant power to hold that memory. You need to disconnect the battery when it sits for long periods of time to avoid this.
Old 07-13-2007, 12:43 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: Battery Drain
well, only one thing to do. if its the problem, just disconnect the fuse!! foind out what doesnt work.if everyhthing works, hey..no prob
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 07-13-2007, 11:45 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Battery Drain
A-have no idea, I would assume the deck lid glove compratment, o rsomething.
B-Instead of disconnecting the battery while in storage, why not use a trickle charger?
