Old 07-12-2007, 07:43 AM
crazybones2084 crazybones2084 is offline
help hookin up my system!
well this is what i got to start i have 2 of these 15's and one amp ! hows the best way to hook up for best sound ! i have a spare 1000 watt sony ! 2 channel but its not enoungh power i dont think ! i just wanna use this new amp!
! XO 15"
Feautres
1. CARBON MICA INJECTION MOLDED CONE.
2. RUBBER SURROUND
3. 2.5 INCH FOUR LAYER HI-TEMP VOICE COIL
4. DVC 4 OHM.
5. 150 OZ. MAGNET
6. DUAL MIRROR NOMAX SPIDERS
7. THE CONE AND SUROUND ARE STICHED AND GLUED
8. THICK HI-CURRENT TINSEL WOVEN ON SPIDER
9. 1000 WATTS MAX, 500 RMS. Sony XM-D9001GTR
1300W Class D Mono Amplifier
View Larger ImageItem# 16547Regular Price: $179.00Our Price: $147.00 Item On SaleMSRP:$299.00You Save:$152.00 (50%)Condition:Brand New, Factory SealedAvg. Rating:Free UPS Ground Shipping!! Rate and read reviews. Technical Specification Features
  • 1300W Max Power
  • 550W x 1 RMS into 4 ohms
  • 900W x 1 RMS into 2 ohms
  • Active Thermal Control
  • Dynamic Distortion Supressor
  • CEA-2006 Power Compliant
  • Line level thru-put
  • High Level Sensing Power On
  • 40 Hz EQ boost
  • MOSFET output stage & power supply
  • Variable 50 - 300 Hz low pass filter
  • RCA & speaker level inputs
  • Subsonic filter (15 Hz)
Warranty: 1 Year Onlinecarstereo.com warranty.1 Year warranty from Onlinecarstereo.com implies that repairs must be returned to Onlinecarstereo.com, not the manufacturer. More information can be found in our help section under returns & warranties. how would be the best way to hook up and get best sound ! all help is needed!
Old 07-12-2007, 08:16 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: help hookin up my system!
did you already buy it? i hope not, but it sounds like it.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 07-12-2007, 09:38 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
those subs are not matched very well (impedance wise) to that amp
Old 07-13-2007, 01:00 AM
AWP9521 AWP9521 is offline
They may not be matched correctly but since the amp puts out mono 900W RMS into 2 ohms he can use 1 voice coil on each sub wired parallel to get the 2 ohm load and have an effective 1000W RMS and 2000W Peak power handling for the system plus an spare set of VC connections if he does burn the one pair of VC's up. Or just use 1 sub wiring the 2 VC's in parallel and keep the other for a spare replacement and get the same results.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 07-13-2007, 01:48 PM
bjboertje's Avatar
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 07-13-2007, 02:22 PM
Originally Posted by bjboertje
Regarding???
Old 07-13-2007, 02:30 PM
PlayStation3 PlayStation3 is offline
Regarding???
if a sub comes with 2 voice coils you have to use both. Companys adding more then 1 voice coil was so that you had better options in terms of ohm loading and it's not an option to not use them. it will be like running a engine with you pulling out half of the spark plug wires.
Old 07-13-2007, 02:33 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
American Bass? Is that the brand? Found a post online saying they ain't bad.
http://www.realmofexcursion.com/foru...ad.php?p=29710
I would throw that Sony product in the trash (its all its good for) or return it.
Get a more proper amp that will closely match the RMS. I'd only hook up one personally, but here is a guide to help you wire it properly, whether you want one or two.
http://www.the12volt.com/caraudio/wo...igurations.asp
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 07-13-2007, 08:48 PM
Audio Guy
******** Warning *************
Do notconnect Just One Coil Of A Dual Voice Coil Sub To An Amp
********* Warning *************
Old 07-13-2007, 09:24 PM
Ok, I admit not knowing much about dual coil speakers, never messed with them personally. Still the 2nd option of using 1 speaker in a parallel wiring with the amp he wants to use is still valid.
Old 07-14-2007, 08:00 AM
Audio Guy
yes, that is ok .... but leaves out a sub, hence my original comment that the amp was not very well suited to the subs (if you want to get full power from the amp).
