Old 07-12-2007, 05:08 AM
upfront9thward upfront9thward is offline
97 grand prix gt
my fuel gage always read full so i changed the sending unit and it is still on full what can be the next problem
Old 07-12-2007, 05:55 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 97 grand prix gt
Did you get the right sender? In 97, there are two possibilities due to a mid-year production change. Also, did you replace the entire fuel pump module, or just the fuel level sensor?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-12-2007, 01:11 PM
just the sending unit and one of the wires the connect to the bottom did not fit so took the one off my old one.
Old 07-12-2007, 03:46 PM
Old 07-12-2007, 03:55 PM
eippermx's Avatar
eippermx eippermx is offline
Wink Re: 97 grand prix gt
This may sound silly. While observing the fuel gauge, wiggle the harness near the connector on the pump. If you see movement, you've got a conductor partially grounded in the cable bundle.
mark
mark
Love my Pontiacs!
'04 GP GT1
'02 Bonneville
'98 GTP - 2 dr
'98 GTP - 4 dr
'99 GP "Flaming Tomato" GT
Old 07-13-2007, 12:12 PM
i don't know what u mean
Old 07-13-2007, 12:55 PM
mark
what do u mean
Old 07-13-2007, 02:02 PM
richtazz's Avatar
If the last 6 digits of your car's vin# are 238198 or higher, the Delco part # is SK1019.
IF it's 238197 or lower, it's Delco # SK1083.
IF you got the wrong one, it will not register the fuel level correctly. Since the one you bought had to be modified to work, most likely it's the wrong one.
Old 07-13-2007, 02:11 PM
richtazz's Avatar
mark
What he means by this is to see if wiggling the wiring connector on the car causes the guage to jump around. If it does, you may have a bad vehicle harness that is the cause of your guage malfunction. The metal contacts inside the plastic plug on the vehicle get weak and will cause intermittent fuel guage operation.
Old 07-13-2007, 03:26 PM
my gauge only move when i put gas in it but ill try that number
Old 07-13-2007, 04:06 PM
eippermx's Avatar
Red face Re: 97 grand prix gt
DOH! Thanks Rich ...Didn't think of the open/weak pins in the connector.
mark
mark
Love my Pontiacs!
'04 GP GT1
'02 Bonneville
'98 GTP - 2 dr
'98 GTP - 4 dr
Old 07-13-2007, 05:16 PM
so move it around with the car on or off
Old 07-13-2007, 08:27 PM
eippermx's Avatar
Put the ignition switch in the run position with out starting the car to perform the wiggle test.
mark
Love my Pontiacs!
'04 GP GT1
'02 Bonneville
'98 GTP - 2 dr
'98 GTP - 4 dr
