Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-12-2007, 04:00 AM
Bootsgamer's Avatar
Bootsgamer Bootsgamer is offline
Send a message via AIM to Bootsgamer
Weak car? Big problem
I have a 93 honda civic. when my car is low on gas it runs really bad but the more gas i put in it the more stable the idle becomes when its low it turns off alot like every time i stop. also when im driving and i press on the gas hard a noise like a light grinding coming from the back that I think might be the fuel pump also when im parked and I turn the key to hear the fuel pump only somtimes it will kick in? isnt it sopose to kick in every time?
Old 07-12-2007, 09:17 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Weak car? Big problem
Check your main relay, change your fuel filter
Old 07-12-2007, 12:44 PM
Bootsgamer's Avatar
Fuel Filter was changed about two weeks ago and a main relay wouldn't do that.
Team Unknown
My racing team
myspace.com/racewiththebest
Old 07-12-2007, 01:53 PM
Kind of a Big Deal
if the main relay is dying, it sometimes wont click on, which in turn wont prime your fuel pump so yes.. that could be part of your problem
Is the gas dirty? if the inside of your tank is starting to rust, it will send those particles into the fuel filter, almost instantly clogging it. to check, take your fuel filter off and drain it backwards into a clear container that it wont eat through. if its excessivly dirty, then either the inside of your lines or tank are rusting. another way to check is to take out your sending unit and look at the pre filter screen
Old 07-12-2007, 02:19 PM
Bootsgamer's Avatar
The car will run fine untill it gets up to temp A bit weak but fine. If the main relay was dying wouldnt it just turn off and not come back on? the car idles bad but its not a constistant bad idle its more like a puttering. also 2 times while dring it has lost power and i had to pull over and turn it off then restart it then it was working agan? I will check out the main relay and get back to ya.
Team Unknown
My racing team
Old 07-12-2007, 05:07 PM
Kind of a Big Deal
if the main relay doesnt click, it wont start... you may be able to try again and it will work...if its only acting up at temp, then it could be your 02 sensor or something in your ignition system
Old 07-16-2007, 02:19 PM
Bootsgamer's Avatar
Ok i checked the main relay its good and i think the grinding in the back is getting louder Im almost sure is the fuel pump theres nothing else back there that could make this kind of grinding?? also it sound to be coming from there?
Team Unknown
My racing team
Old 07-16-2007, 09:15 PM
Kind of a Big Deal
could be. its easy to replace, good luck
Old 07-17-2007, 12:44 PM
Bootsgamer's Avatar
Thanks GreenBlurr93
Team Unknown
My racing team
Old 07-26-2007, 07:09 PM
Dimension_X Dimension_X is offline
Send a message via AIM to Dimension_X Send a message via MSN to Dimension_X Send a message via Yahoo to Dimension_X
Hey, this may be way late for advice. But I took my car into a shop recently, 2000 Honda Accord and I overheard the mechanic talking about Japanese cars and fuel....apaprently if a import car (Toyota Honda etc.) if you run out of gas its screws up the timing or something like that and he said that you need to replace all your sparkplugs and wiring. so I dont know if thats the problem but I thought it was an interesting bit of info.
Old 07-27-2007, 10:19 AM
Kind of a Big Deal
its also not true..
Old 07-28-2007, 02:17 PM
Bootsgamer's Avatar
I have never run out of fuel with it and i dont think theres any cars that when you run out of fuel you have to change the spark plugs.
Team Unknown
My racing team
