Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 07-11-2007, 10:50 PM
1987 CRX HF 1987 CRX HF is offline
D16Z6 head on a D16A1
Im not sure if this is possible but from what my research says this is called the mini me swap?
anyone done it or know anyone who has done...give me some pointers plz
thanks
CReX:
Old 07-15-2007, 01:41 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: D16Z6 head on a D16A1
This swap won't work on a D16A1, D16A3, D16A8/9, DOHC ZC, or EW/D15. There is one head bolt hole that won't line up, oil passages are different, and there is no timing belt that will fit without a custom made bracket for the timing belt idler pulley. You will need to rewire the car to run the electronic advance distributor and VTEC. This swap will also increase the compression ratio significantly enough to where you risk detonation if you fill the tank with pump gas.
FYI, the DOHC head flows better than the D16Z6 head.
Old 08-08-2007, 02:15 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
actually, it IS possible, but not worth it... you'd have to bolt the head on, have the block machined for that one bolt hole, or the head, either way, backfill with weld, which could break, etc. you'd also have to change your pistons, b/c the chance for interference is too high with that combination of parts... you'd have no possible valve timing advance w/o risking hi-rev interference.
also, the D16A1 head is better if you wanna turbo it or anything like that, b/c it has better flow, and if you wanna use Vtec, there are several diff builds that you can do that don't require milling parts to get them to fit right.
