Old 07-11-2007, 11:28 PM
jonathanc's Avatar
jonathanc jonathanc is offline
Tire Size Fit
I have an 04 Silverado Crew Cab Z71. If i were to get a 3in body lift would 35's fit on the truck? If so does anyone have these tires http://www.nittotire.com/#index%2Eti...ler%2Eoverview with this setup. If this setup is possible could you please show pics? Caqn i put a 35x12.5xR17LT tire on my factory 17in rim?
Old 07-11-2007, 11:50 PM
01silverado03z400's Avatar
01silverado03z400 01silverado03z400 is offline
Send a message via MSN to 01silverado03z400
Re: Tire Size Fit
Do it! It'll work on ur stock rims with a crank of your torsion bars but after market rims might make them rub. I have the same setup except i have bfg all-terrains.
NEW - 2004 Chevrolet Silverado 5.3L RCSB Z71 Hooker AeroChamber - Black Bear Tune - Welds - 33" Mickey Thompsons
01 Silverado 4.8L ECSB 4x4 True Flow - Magnaflow - Black Bear Tune - 35" BFG A/T - 4.56 Auburn SOLD
83 Sierra RCSB 2wd 350 Under construction
Old 07-12-2007, 12:25 AM
jonathanc's Avatar
Re: Tire Size Fit
Are 12.5 wide tires not too wide for the stock rims? My tires are 305/70R17 so they are bout 11in wide now.
Old 07-12-2007, 12:30 AM
jonathanc's Avatar
Re: Tire Size Fit
So what kind of mods do you have on your truck? You have a suspension lift rt?
Old 07-12-2007, 01:04 AM
Re: Tire Size Fit
They're wide but they'll still fit. And the tire u have on is about 12inches wide. 305 = 305mm which is like 30.5cm which is a little over 12 inches.
I have a 3" body lift and a 2" keys and blocks lift.
Old 07-12-2007, 01:09 AM
jonathanc's Avatar
Re: Tire Size Fit
What do the 2in keys do? Isnt that the same as jus cranking the torsion bars? Im new to all this so im tryin to figure it all out.
Old 07-12-2007, 01:14 AM
Re: Tire Size Fit
blocks lift? That for the back of the truck? What do the 2in keys do? Isnt that the same as jus cranking the torsion bars? Im new to all this so im tryin to figure it all out.
ya stock blocks are 2" and i changed mine out for 4" blocks in the back. And you can only get about an inch out of ur torsion bars by cranking them and ur truck will ride like shit but keys let u go to 2" without putting too much stress on your front end components.
So right now i line up with most 6" suspension lifts and run 35" tires on a 4" backspaced rim with no rubbing at all.
Old 07-12-2007, 01:19 AM
jonathanc's Avatar
Re: Tire Size Fit
Thank you so much. Ill look into all this. Im sure ill have more questions. Oh yeah i really like your truck. I wish mine looked like that. Mayb soon!!!!!!
Old 07-12-2007, 01:22 AM
jonathanc's Avatar
Re: Tire Size Fit
Jus wonderin y didnt y u get add a leafs for the back or bigger blocks?
Re: Tire Size Fit
thanks man. body lifts are kinda ghetto unless you cover them up good. If i was to start all over and do it all at once id just get a 6" suspension lift.
Old 07-12-2007, 01:25 AM
jonathanc's Avatar
Re: Tire Size Fit
i wonder how those tires, stock rims, and a 6 in susp lift would look? I think the wheels may look 2 small.
Old 07-12-2007, 01:27 AM
Re: Tire Size Fit
i did get bigger blocks. And add a leafs were more expensive and the shop told me to just go with the bigger blocks. Some ppl run like a 6" suspension lift with an 8 inch block in the back so im sure a 4" block cant be that bad.
Old 07-12-2007, 01:29 AM
Re: Tire Size Fit
Most 6" suspension lifts usually require aftermarket rims with at least 4" backspacing or so. And most ppl usually run 35s on a 6" lift. Oh and keep in mind that u should probably regear when going to a 35 or bigger tire.
Old 07-12-2007, 01:45 AM
Re: Tire Size Fit
I figured that. How much does it cost to regear?
On a 4x4 u gotta do front and rear diffs and u should probly get a stronger posi put in. Mine was just over 2000$ canadian installed for 4.56 yukon gears and auburn posi. I think gears alone would be about 1000$.
Old 07-12-2007, 06:00 PM
jonathanc's Avatar
Re: Tire Size Fit
What would happen if i didnt regear when i got larger tires?
