Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-11-2007, 08:35 PM
Burnindesirez02 Burnindesirez02 is offline
Why does my alarm keep going off?
My brother just got a 1997 GST a few days ago and the alarm goes off once in a while as if its short circuiting. I don't know where to look for that at because im not especially into the eclipses. I have a Civic. anywayz i goes off whenever it wants basically except when we are driving. also how do you change the fog light bulb? thanks
Old 07-12-2007, 01:19 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Why does my alarm keep going off?
Is this the stock alarm or aftermarket?
As for the fog light, they are a PITA to replace. The one big bolt that holds the fog light housing in is usually rusted pretty bad and hard to get off. Basicly you just let it soak in WD-40 or whatever your choice lubricant for a few days if you have trouble. To replace it, you just take off the front cover thats held on my one screw, then you will see several screws holds the housing in place. Take those out, swear at them a bit for good measure. Then once you get the housing out, there are a few screws to get it apart. Then it's just plug and go with the new bulb and put all the screws back.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-12-2007, 02:09 PM
It is a stock alarm
Old 07-13-2007, 10:46 AM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
That problem is very hard to diagnose becuase the factory alarms are programed into the ECU. It recieves its signal from various objects on the vehicle. Mainly the door switchs. If you look in your door jams you will see a little switch that tells the ecu when the door is open or closed (if you push the switch in and out and your open door lamp goes on and off you have the right switch). Make sure those switches are working properly, if they are malfunctioning this could be causeing the factory alarm to go off. Other than that you may have an ECU problem.
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
