Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-11-2007, 04:53 PM
fyremanvan fyremanvan is offline
2001 Dodge pick up steering
I have a 2001 dodge 2500 diesel. I have been having problems with the steering. At an idle the truck is very hard to turn to the right. To the left is fine. When the truck is cold it works for a while then gets hard when it warms up. While driving at a higher speed it works fine. Took it in and had a new pump put on but that did not fix the problem. The mechanic is stumped as I am. Any thoughts????
Old 09-15-2007, 11:29 PM
rockwood84 rockwood84 is offline
Re: 2001 Dodge pick up steering
could be in the steering box worm gear
Old 09-16-2007, 04:26 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I agree with Rockwood84. You might try letting somebody turn the steering wheel with the motor running and foot off the brake while you look for anything unusual under the front of the truck (after taking the usual safety precautions, trans. in park, parking brake set).
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 09-16-2007, 07:27 PM
wayneo69 wayneo69 is offline
almost sounds like the intermediate shaft but that would have a tight spot in any direction
