Old 07-11-2007, 01:44 PM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
1995 4.3 A/C compressor clutch problems
Got a question for you A/C inclined guys.
I have a 1995 Blazer Lt with A/C.
When the solenoid engaged I would get this dragging sound and the belt would start to slip. I figured it was the clutch so I disengaged the solednoid and have had no further problems. The air was still plenty cold until this problem, then it was not working well at all.
So what Im wondering is should I buy a new clutch and solenoid assembly and just replace it?
Has anyone pulled their clutch? How do I go about getting it off?
Anyone think it could be anything else?
Old 07-11-2007, 01:57 PM
tas97459 tas97459 is offline
Re: 1995 4.3 A/C compressor clutch problems
do web search for tools removal compressor clutch
Old 07-11-2007, 03:00 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You can jumper the dark blue or green wire at compressor clutch with AC controls turned off and engine running.
Use a fused 12 volt jumper wire.
Clutch should click in good when jumper and release good when unhooked.
Watch for clutch plate drag when unhooked and check for proper clutch plate clearance.
Also good idea to check the compressor front hub bearing.
AZ and some parts places loan or rent the tools to change the clutch.
Good luck
MT
MT
Old 07-12-2007, 08:50 AM
Thanks guys.
After doing some reading I think it may be the bearing. Ill have to do some diagnostics when I get back from vacation.
Old 07-12-2007, 09:54 AM
MT-2500's Avatar
AF - Advisor
Originally Posted by JoulesWinfield
Thanks guys.
You are welcome and let us know how it goes.
When you take the belt off you can feel the bearing to see if it is bad.
Good Luck
MT
MT
Old 07-14-2007, 04:18 PM
The bearing feels fine with the clutch disengaged but as soon as it engages it starts making noise and the belt squeals a little.
Old 07-14-2007, 04:45 PM
MT-2500's Avatar
AF - Advisor
The compressor is bad.
MT
MT
