Old 07-11-2007, 12:00 PM
bolivas's Avatar
bolivas bolivas is offline
2000 Z71 squeaks in reverse??????
First let me apologize if this topic has been covered before, but I tried a search and came up empty.
I have a 2000 Z71 that squeaks sort of the way the squeaker on brakes do, but it only happens in reverse and the rate increases as the speed does. I can roll the truck backwards in neutral and the sound is not there. It only happens in reverse. Any help would be appreciated.
Thanks,
bolivas
Old 07-12-2007, 06:02 AM
jake2775 jake2775 is offline
Re: 2000 Z71 squeaks in reverse??????
i have the same problem only in forward ...... when throttle is applied i have a rubbing / squeeking noise , i assume its maybe a U-joint , but not 100% sure.
Old 07-28-2007, 11:43 AM
sierra99 sierra99 is offline
I had the same problem....It sounded like I had a tire rubbing. Somebody told me it may be a ujoint, but I refused to listen. Guess what??? They were correct....Do yourself a favor, and replace both ujoints at once. I did not and the other went bad within 2 month after the first. I had to go back and forth to the parts store because they had about 4 different ujoints for a 99 silverado. So either buy them all and repalce what you do not use or bring the ujoints into the store after you pulled them out. I got mine from NAPA from another guy here that posted that on this site.....
Thanks to all.......
Old 07-28-2007, 12:05 PM
yea mine was the same thing, it was indeed the u-joint . solved my squeeking problem.
Old 07-30-2007, 10:06 PM
bolivas's Avatar
Thanks to all who have replied. Sounds like I know what I will be doing on my next 4 day. I will let you all know if this fixes it.
Thanks again,
bolivas
