Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 07-11-2007, 10:40 AM
m. gary m. gary is offline
car won't start ? ignition
i have a 96 jetta manual shift with a 2.o engine . my car will not start well i should say it only seems to start in the morning. i been told that its the ignition switch which seemed logical b/c i did notice that the key seemed to have to turned further when it was starting. yesterday when i was trying to start the car i felt the key getting hot..do i need to change the whole ignition thing or just where you put the key at. has anyone gone through the same thing please advise b/c i been parking on hills for the past two days and haven't been able to turn car off if one is not around
thanks
Old 07-13-2007, 03:21 PM
Doug Tatham Doug Tatham is offline
Re: car won't start ? ignition
If your key is getting hot because of a serious short, then you should be blowing fuses.
Try hot wiring it (directly at the starter) and see if that works, if it cranks, start tracing from the starter to your ignition switch. I'd advise getting a service manual before you try to fix the ignition switch. The give some good pointers.
Old 08-12-2007, 02:05 AM
2001jettavr6 2001jettavr6 is offline
if the key is getting hot its probably because the connection is being made in the igniton but the ignition is bad, thats one thing, if you try to start it but hear a clicking noise its the starter, or the ignition coil
Old 08-12-2007, 10:18 PM
ctuagent117 ctuagent117 is offline
does it sometimes take you 2 or 3 times to start the car?
Old 10-14-2007, 04:58 PM
mjglate mjglate is offline
thanks it was the ignition switch automotive forums rock
