Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 07-11-2007, 07:52 AM
sdlsweet sdlsweet is offline
Question 2001 Pontiac montana
I have a 2001 Montana and my headlights are very dim, I have to drive continously on high beams, does anyone know why? or got advice? Also on my drivers side headlight cover, there is a small hole in it, when it rains water accumulates inside, I have dried it out and sealed the hole, however my parking light and blinker don’t work, when my husband took it apart the wiring for the bulbs was burnt beyond repair, anyone know how to fix it?
Old 07-11-2007, 12:37 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 2001 Pontiac montana
Are your headlamp covers dirty or cloudy? That is a common issue on many vehicles no matter who made them. Some people have found that by removing the headlamp capsules and gently washing/rinsing them out can take away some of the film inside the lens that impedes the light. If they are too far gone to clean they may also be faded from the sun's UV rays deteriorating the plastic. You can get new headlamp capsules on eBay pretty inexpensively.
Concerning the burnt wires for your turn/parking light, you may have to cut off the damaged wires and socket and replace with new to correct the problem. I've seen many GM minivans with this issue and one thing that may cause it is a excess buildup of moisture.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 07-11-2007, 06:28 PM
GTP Dad GTP Dad is offline
Pontiac Guy
As 97ventureowner stated change the socket and wiring to get the parking light to work. Not a hard job to do but sometimes the wiring may be hard to get to. Also have your husband check the ground wiring to your headlights. It sounds like there may be an issue with the low beam side not getting a good enough ground to allow them to work properly.
Old 07-11-2007, 06:34 PM
Also, after you replace the socket and wiring, make sure the connections are well sealed and water tight. Use a little di-electric grease in the socket to repel moisture. This grease is used for that purpose without hindering electrical current.
Old 09-29-2007, 03:48 PM
talagg1 talagg1 is offline
I have a 2001 Montana with the check engine on. The codes first displayed that the O2 sensor was faulty so I replace both up and downstream sensors.
After I repalced the sensors and cleared the codes and I now have a solid Bank 1 fuel too lean code that will not go away. Does anyone know where I should start?
Thanks.
