Go Back   Automotive Forums Car Chat > Ford > Mustang > Non-Performance
Non-Performance This is the place for all interior, exterior, and general non-performance modifcations.
Old 07-11-2007, 01:34 AM
MRDANGERUS MRDANGERUS is offline
Question 86' 3.8L V6 temp sending unit location
Could anyone tell me where is it located? My gage shows 0 all time. Have to replace sending unit or wiring.
Thanx
Old 07-11-2007, 07:11 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: 86' 3.8L V6 temp sending unit location
Oil sending unit? Just look around on the block for a sending unit. On 5.0/5.8's they are low down on the driver's side near the front of the block.
1969 Cougar
357w & TKO - 475hp
Old 07-11-2007, 11:00 AM
Thanx
I'm trying to locate a coolant temperature sending unit.
Old 07-11-2007, 01:14 PM
351wStang's Avatar
Look on the intake. Should screw into a water jacket.
1969 Cougar
357w & TKO - 475hp
Old 07-11-2007, 02:54 PM
Hi,
Thank you v much.
BTW: I 'm looking for a shop manual for the 86 Mustang or just the engine diagnostics manual. Do you know of any free download?
Engine sounds like a diesel when idling and cold, almost like broken valve spring. Listened with the stetoscope, engine sounds good. The only "crunch" comes from the air pump.
Only 58,000 mi on the bloody car. It run perfect. Gasket blew at 33k due to over- heat caused by rust blocked OEM cat. Got it rebuilt by some yahoo-s in town. It is sluggish, since. May be they did not install timing chain properly? I have played w/the strobe and vacuum gage trying to get optimal timing advance. Still sluggish.
Oh, last summer, my woman took it to the "garage" and they put a pink antifreeze in it. On the way back home she boiled the fluck out of it. I drained and flushed this crap. No more overheating.
I may have to run a compression test, but to check springs? May be I should try blow by test?
