Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-11-2007, 12:02 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
oiled head
i am not getting any oil on my head. I finally finished my 6 bolt swap. I started the motor after priming the engine. Oil doesnt make it from the pump to the head. I purchased all the 6 bolt parts to make it work in my 97 gsx. the oil is filling the filter and front case, its just not making it to the head oil ports. it has plenty of oil. what would the likely scenerios be?
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 07-11-2007, 09:01 PM
Re: oiled head
guess it is too late for me to put this in the problem diagnosis thread...
72 Beetle - trashed
92 Talon - sold
Old 07-11-2007, 10:12 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: oiled head
It really sounds like the pump isn't working to it's full capacity. Sounds like it's not pumping it through. Is it new?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-12-2007, 10:22 AM
Re: oiled head
the head and block are fully rebuilt, the front case and pump are supposed to be new, but they are probably rebuilt as well. everything on this motor has 0 miles on it. I put an impact wrench on the pulley also, spun it to about 500 rpm, still doesn't flow through. both balance shafts were removed though, but that shouldn't make a difference.
72 Beetle - trashed
92 Talon - sold
Old 07-13-2007, 10:48 AM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
Re: oiled head
Did you make sure the head gasket had the correct oil flow ports in it before installing it? I'm sure you did, but you never know.
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
Old 07-13-2007, 09:53 PM
Re: oiled head
i hope it was installed correctly, a business built it for me, but with all the issues I have been having, i wouldnt doubt it. the oil drops down from the head into the pan. im going to try and blow air through the holes to make sure it is passing through. anyone have any tips or advice for fixing the pump?
72 Beetle - trashed
92 Talon - sold
Old 07-14-2007, 12:11 PM
david-b's Avatar
Dave is THAT guy
Re: oiled head
Replace? Best I can think of.
Did you get in touch with the shop that built it?
75 Monte Carlo
Old 07-14-2007, 11:27 PM
Re: oiled head
Remember though, you need to test the ports from which the oil pump send oil up to the head.
Old 07-15-2007, 12:25 PM
Re: oiled head
working on it, i will post updates on it. its just here in florida, it rains every day. so i just have to wait til its dry so it doesnt get water all in it and rusts
72 Beetle - trashed
92 Talon - sold
Old 08-09-2007, 06:30 PM
Re: oiled head
alright, so i get a day off when its not raining. I pulled the front case off, also took the oil pump out. It appears the clearance is within specs. I took an air compressor to force air through the system, in the direction it is supposed to go.
I pumped 140psi ofair in the hole with the arrow and blocked that hole with an X. From what I found, air is flowing through to the pistons, and I can feel air all around here.
As you can see though, the head is still dry, except for the original oil fill that remains. I cannot feel any air flowing, nor does any air make it here.
Anyone have any idea how the oil cant reach the head or how 140psi air doesnt either? Would this have anything to do with the head gasket and is there a possibility of putting it on backwards? Where are the holes located that the oil is supposed to be flowing through in the head?
72 Beetle - trashed
92 Talon - sold
Old 08-09-2007, 06:37 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: oiled head
Did you use the same lifters or different ones? If you got new ones then they need to be primed before you can use them... In case that step got skipped... If they aren't new, then I would say your problem lies more so in the oil pump/front case...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-09-2007, 07:03 PM
Re: oiled head
every moving part is new; new lifters, springs, pistons, and oil pump. I cant think of any other way to prime. how else would you do it? the block appears to be getting plenty of oil.
72 Beetle - trashed
92 Talon - sold
Old 08-09-2007, 08:07 PM
Re: oiled head
You submerge the lifters in... I believe we used kerosene? And you have to use a paperclip and stick it in the end of them and then pump them up while submerged and holding the paperclip in until all the air is out of them. If not, when you start the car up then they will go flat and fail to support oil to your cams and such... I'm pretty sure it was kerosene we used.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 08-10-2007, 12:51 AM
Re: oiled head
Take your head off and look at the head gasket like I said earlier. They could have put the wrong gasket on with different oil ports. you need to see if the air is making it through the gasket.
Old 08-13-2007, 12:06 AM
Re: oiled head
after taking off the cams, I can tell some oil had flowed through to soak the braces. apparently I didnt prime them good enough with 5w-30 oil. took out the lifters again, I can still compress easily with my hand. I'll try the kerosene. also I did some research on the head gasket, before I venture on an 8 hour job with it, I don't see how the wrong one could have been put on, and from the design, it cannot be put on backwards or upside down. unless one had been cut out or customized. right now I am working on putting the oil pan back on so more air could be forced to the top. sucks working on a car when you dont have a garage though, living in florida, it rains every other day in the summer, if it doesnt rain, its 99 outside.
72 Beetle - trashed
92 Talon - sold
