Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-10-2007, 11:51 PM
airtight_python airtight_python is offline
Stuck key
My buddies 2001 Azteks ignition started screwin' up. When trying to turn off the vehicle the key will not turn all the way to the "off" position. The accessories stay on and the key will not come out. If you giggle the shift handle or throw it into park fiercely, every now and then the key comes out...
What gives?
Old 07-11-2007, 01:54 PM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
Re: Stuck key
Sounds like an issue with BTSI either bad or bad connection
Old 10-08-2007, 03:33 PM
emt1134 emt1134 is offline
Re: Stuck key
Remove enough of the console to access the shifter.. you will see a switch on the side. remove the connector and check for loose connections. If connections are good, you will most-likely needs a new shift lock switch.
Old 10-14-2007, 06:09 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Stuck key
thankx for helping out emt1134, but please watch the dates!
1999 Grand Am SS 3.4 OHV
Closed Thread
