Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-10-2007, 06:12 PM
knewman knewman is offline
Exclamation Need a little help Cummins
I have a 2001 Ram 2500 cummins diesel. The past few days (with no check engine light) the truck seemed to go into some type of limp mode very similar to newer duramaxes. Upon first start up when I try to drive the truck it wont go over 2000 rpm and has llittle power. If I shut it off and restart it. the truck runs perfect with full power. Any ideas what this might be
Old 07-11-2007, 05:38 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Need a little help Cummins
Yep, mine did the same thing right after making a fair sharp right hand turn. After taking the TPS/Accelerator Pedal Position Sensor(APPS) loose, disconnecting & re-connecting it several times, mine quit doing it for a year. When it started doing it again a year later, I did the disconnect/re-connect drill again.
Turn your keyswitch on-off-on-off-on then look at your odometer for trouble codes...some will not turn on the Check Engine light.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 07-11-2007, 07:58 PM
I will give it a shot and see what happens. Thanks
Old 07-29-2007, 05:19 PM
lilfroger's Avatar
lilfroger lilfroger is offline
A lot of people describe the same situation when the limp pump is going out.
'06 Dodge 3500 Cummins 'Big Horn Edition'
35" Pro Comp A/T
2" leveling kit
