Go Back   Automotive Forums Car Chat > Buick > Grand National/GNX
Old 07-10-2007, 03:52 PM
SkidooZ08 SkidooZ08 is offline
how to set timing on 86' grand national
if anyone could tell me how to set the timing for an 86' grand national it would be extremely helpful for my friend and i. its together now it runs very rough and we think it could be timing. just let me know please!! thanks
Old 08-06-2007, 11:45 PM
justav6 justav6 is offline
Re: how to set timing on 86' grand national
its probably not the timing. by runs rough you mean idle or cruise or full throttle? is the car stock?
Old 08-10-2007, 03:06 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The turbo Regal GNs in 86-87 didn't have a distributor, so there is no way to set the timing. If the spark timing is off, it's either a wopped out timing chain or a bad ignition module, crank position sensor or cam postion sensor.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-29-2007, 10:16 PM
87 GRANNY 87 GRANNY is offline
87 regals had no distributors but they have cam position sensors in the distributor location. 86 cars as far as i know had this same set-up. Timing can be set by rotating this sensor as we did the distributor it is done with a
mulimeter to determine number one tdc position . A manual does explain in detail-not saying this is your problem but if this sensor has been tampered with or moved timing should be verified.
Old 01-05-2008, 10:35 PM
alb84 alb84 is offline
There is no adjustment for the timeing. It runs when the cam sensor is set correctly, and it will not run if it is not. There are many things that could make it run rough, but that is low on the list unless you tried moving it. If you did, then you can go to the Turbo Regal Site @ gnttype.org. There you will find information on how to set the cam sensor. So if you could give us a little more info on the rough running maybe we could figure it out.
Danny
Old 01-05-2008, 10:56 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Thanks for your input guys; however, this is an Older Thread that should not be resurrected!
