Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-10-2007, 02:24 PM
somick's Avatar
somick somick is offline
Loud roar after timing belt replacement
It is hard to describe a sound but that what I hear: a very loud roaring sound that develops after 2000 rpm. Sometimes it sounds like a tractor trailer.
It all started after the timing belt replacement.
I know I am guilty: I bought OEM timing belt but stop short on buying OEM balancer belt. I bought the cheapest for 10 dollars vs. dealer’s 25. May it cause the noise?
I did not torque the pulley right (did not have torque wrench at the time).
When I look at the pulley it looks like it wobbles a little. No more than 1mm.
So I rented a torque wrench from Autozone and planning to torque the pulley to the correct torque this weekend (181 ft/lb).
Will it help me to get rid of noise or should I live with it till the next belt replacement?
99 Accord LX with 74,000 miles. The car is 96 month old and the maintenance schedule calls for timing belt replacement at 84 months.
Any ideas or suggestions are greatly appreciated!
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 07-11-2007, 01:41 PM
somick's Avatar
Re: Loud roar after timing belt replacement
Well, well...
I guess I will ask this question at another forum.
Thanks for reading,
Sam
Old 07-14-2007, 03:52 PM
somick's Avatar
I am LAZY, LAZY, LAZY, LAZY!!!
I am ashamed of myself!
The balancer belt was installed 180 degrees off TDC. I most likely made uneven number of revolutions of the crankshaft and then installed the balancer belt.
Everything is fixed! Hopefully I did not ruin my engine.
On the good note: the second time it took me only 45 minutes to get to the belts. The experience matters!!!
I hope that somebody when searching will find this thread and will not make the same stupid mistake.
Thanks everybody for ideas and support. Thanks for the help!
Sam
Old 08-10-2007, 10:25 PM
tim96460 tim96460 is offline
If it is worse when cold the belt is loose, if so 15 minutes is all it takes to fix the problem.
If i
Sam
Old 08-11-2007, 12:15 PM
somick's Avatar
If i
Thanks, tim.
I probably did not expain it correctly in my last post:
When I installed the balancer belt I did not verify the marks and as a result it (the balancer belt) was installed wrong: 180 degrees off (up side down).
It is all fixed now. The car runs like a champ!
Thanks for your suggestion,
Sam
Old 08-13-2007, 11:57 PM
Oppps, hey I am human too, glad you got your car running good.
Thanks, tim.
Sam
