Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 07-10-2007, 12:12 AM
TexasGuy TexasGuy is offline
Cool Weird distributer o-ring oil leak problem
'05 120K 3.1V
I had some oil leakage for some time. Took it to the shop finally about a week ago, they replaced a few gaskets including o-ring under the distributer mount, paid quite a penny. Now after a few days it leaks again, by far not as hard but definitely leaks exactly under that mount on which the distributer sits. Sure I will take it back to the shop but would be nice to hear why would it still leak.
Other than that the car worked and works fine.
Any advice?
Old 07-10-2007, 07:30 AM
LMP's Avatar
LMP LMP is offline
Re: Weird distributer o-ring oil leak problem
Yeah..too bad ..a common problem on ALL having this block, even when they have no distributor at all but just a cap....including my son's Z-34 that, even with different DOHC heads, uses the same block and gasket....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 07-18-2007, 07:30 PM
ESP6 ESP6 is offline
I would agree. It is very common. I've changed em 5 times myself.. The Gaskets cheap as long as you reinstall the distributor into the same position. Good luck, mine allways cook and the O-rings become rock hard.
1993 Ford F150 300 4.9L 2wd
1994 Nissan Altima GXE 2.5L DOHC 5-speed
Old 07-19-2007, 05:59 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Do yourself a favor, and also install an old small block Chevy paper distributor gasket (Fel-Pro part # 70194) between the top of the block and the distrubutor/oil pump drive housing. It won't leak again.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-21-2007, 09:26 PM
Thanks for the #. I'll try it. Everyone in these parts have never heard of it. So I'll have them look up the #
Old 07-23-2007, 12:02 AM
http://www.amazon.com/Fel-Pro-70194-.../dp/B000C2CCLQ
