Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-09-2007, 09:31 PM
1988camaro 1988camaro is offline
88 camaro problem
there is a bar that goes from ur rearend to the back of the trans thats givin me problem i put a new motor and trans in the car and that bar is not long enought to reach the trans can i just take that bar off the car and put traction bars or does that bar have to be hooked up to the trans
Old 07-10-2007, 01:01 AM
Morley Morley is offline
Re: 88 camaro problem
Torque arm...without it your rearend will try to depart the car on a hard acceleration.
Old 07-10-2007, 02:23 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
you put in a th350 or something?
Old 07-10-2007, 11:04 AM
yes i put a th 350 the car was a 2.8 but i put a olds 350 rocket in it so i have no way to hook up the bar what should i do
Old 07-11-2007, 02:22 AM
Spohn and others make a trans crossmember with a mount for their own aftermarket torque arms, so you don't need the "special" tail housing for the torquearm mount. http://www.spohn.net/
Old 07-11-2007, 03:32 AM
Genopsyde's Avatar
The President
isn't there a difference in driveshaft length also?
Old 07-11-2007, 10:41 AM
yea i did have to get a longer driveshaft but the only problem i got left is the torque arm and i dont know what to do i could get it weilded longer but there isnt a way to hook it up to the back of the trans
Old 07-11-2007, 04:48 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
It dont have to hook to the back of the transmission. In fact its better to use the crossmember bolts. You cant just weld it up solid it has to be able to move around. As mentioned, aftermarket parts might be the way to go. By design they usually attach to the crossmember wich would be a sure fix for one of your problems. They are adjustable but i dont think you can "stretch" them you will still likley be in for some metal fab.
Old 07-28-2011, 12:58 PM
country70 country70 is offline
I have a problem with a 88 camaro as well can you help me please
