Old 07-09-2007, 08:54 PM
cwhitty cwhitty is offline
Wink $$Cost$$
I was just wondering if any one could give me a ball park figure of how much it will cost to replace the valves in a 1997 blazer 4x4 and how much a compressor will cost
Old 07-09-2007, 09:28 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: $$Cost$$
Kinda depends on how much other stuff you need with the valves.
Tell us what all it needs with the valves?
If you are have a repair shop do it they will give you a estimate before repair.
If you DIY it have a machine shop give you a estimate on head work.
And check with parts place on parts cost.
A new compressor will run in the 2-3 hundred range for a brand new one.
MT
Old 07-10-2007, 07:35 AM
badassblazer91 badassblazer91 is offline
Re: $$Cost$$
couldnt you rent a compressor from autozone or advanved
Old 07-10-2007, 08:46 AM
MT-2500's Avatar
AF - Advisor
Re: $$Cost$$
I the poster was asking about a AC compressor.
Tool rental places may rent Air compressors.
Not sure about AZ or Advance But give them a call.
MT
MT
Old 07-10-2007, 10:28 AM
Re: $$Cost$$
Ok here's the thing I don't know what it needs with the valves. I was just told that the clicking noise mwas coming from my left side valves.
Old 07-10-2007, 12:08 PM
MT-2500's Avatar
AF - Advisor
Re: $$Cost$$
You may or not need valves.
Pull the valve covers and have a look at things.
Could be a lose rocker arm or bad push rod.
How is the oil pressure?
MT
Old 07-10-2007, 05:04 PM
AJT1961 AJT1961 is offline
Re: $$Cost$$
It could also be a leaking lower intake manifold gasket. On my 2000 Blazer, the first symptom of a leaking gasket was an intermittent valve tap on the left side of the engine -- even before there was a perceptable drop in the coolant level.
