Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-09-2007, 03:38 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
hatch pull-down mechanism
My sister was recently inducted into the Camaro club, she bought a 1991 3.1. Among other various minor things to fix is the hatch pull down thing. I never had a problem with my other 3rd gen. So, is it all one piece that needs to be replaced, or is there a relay or motor or what? As of right now it won't close, no matter how hard she slams it (bad idea) lol. I know this is a common problem on 3rd gens, but I have no knowledge of this particular fix. Help!
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 07-10-2007, 12:59 AM
Morley Morley is offline
Re: hatch pull-down mechanism
It is several pieces, relay, switch, motor, gearbox and cutoff switch. Check here http://www.top-downsolutions.com/pro...95a10d6849093b for the repair kit. Lon is a great guy to deal with and has everything you'll need, and then some.
Old 07-10-2007, 12:43 PM
SG007's Avatar
thanks man
Old 07-10-2007, 01:49 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
the thing that usually goes up in thoes is the gears or motor. the gears are plastic and the teeth wear off. then the motor will keep running and either burn up or kill your battery. i took mine apart and locked it in place so when i put it back in, it just latches and unlatches like a regular hatch.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 07-29-2007, 02:47 AM
dgpfc dgpfc is offline
hi im having a similar problem on my mates 89 firebird , ive dismantled and tested off the car and motor and gears seem to work fine. when fitted back in i dont seem to be getting power , can you tell me which fuse and where and if that is good how do you test the relay, cheers dave
Old 07-29-2007, 01:39 PM
Firebirdlad03 Firebirdlad03 is offline
Send a message via AIM to Firebirdlad03
simple way to check that fuse....open the door..if the dome light turns on..ur good...pretty sure they r on the same one..along with a few other things..
Mitch
92 Firebird formula...
Old 07-31-2007, 10:28 AM
NoRiceHere01 NoRiceHere01 is offline
i wouldnt worry about the fuse.i did the same as the moderator and unplugged mine because it would jam or just die as if it wasnt getting enough voltage.i plugged it in and tripped the switch that makes it go down with my finger, then when it got to the right height i unplugged it real quick.now it just opens and closes like a normal trunk.the trick is just to get it to latch low enough to seal, but high enough that you dont have to slam the hatch too hard.
