Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 07-08-2007, 09:40 PM
slick1999222 slick1999222 is offline
93 Starter problem
I have a 1993 explorer with the v6. the starter stopped working one day it clickks... we removed the alarm system, and still the same thing. we then had the starter tested and its fine... any sugestions would be greatly appriciated
thank you so very much
Old 07-08-2007, 10:37 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 93 Starter problem
Do you get a series of clicks, or just a single click when you try to start it?
If a series of clicks, it sounds like the starter motor or solenoid is struggling to get enough voltage/current. If that's the case, you should start by checking the battery cables to make sure they are clean and tight. Don't just glance at them, pull them off the battery and make sure they're clean. Also, if you have temporary clamps that bolt on to the battery cable, throw them away and replace them with the OEM-style molded battery cables.
If the cables are clean and tight at the battery, check the connections at the other end. If all that checks out, you should have your battery load tested.
If you get just a single click, then the problem is probably the starter, even though it tested okay on the bench.
-Rod
Old 07-11-2007, 06:58 PM
squeaky3 squeaky3 is offline
another thing
if it is a single click then ur starter could be workin but it cant push the flywheel
ur engine may be stuck
i had this problem on a diff car last year
if u can hook up a VAT-40 or something similar and c if the starter is drawin to many amps from the battery
just my .02
Old 07-19-2007, 10:34 PM
jacobunderwood jacobunderwood is offline
well is it manaul or automatic well some of the security systems are very conplex so i would just take it to a mechinac and see what they would say. it should take to long to figure out.
Old 07-24-2007, 02:52 AM
colt450 colt450 is offline
Banned
That is right seeking proffesional car care is a good idea.
