Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-08-2007, 08:27 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Rattling from Cat
So I've had this going on for awhile, but just now gotten really bad. There's a rattling coming from the cat. It sounds like metal on metal hitting, so I always thought it was my exhaust hitting the heat shield, but it's not. I actually took a small C-Clamp once and put it on the ends of it on the one side and tightened it up. The rattling did stop amazingly. Well that fell off and now it's doing it worse. Do I need a new Cat? It's only 2 years old! What the crap yo?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-13-2007, 02:14 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Rattling from Cat
Mine was just doing this last week. It turned out to be the heat shield on the top of the cat. Apparently the spot weld let loose in one corner and the heat shield was smacking against the top of the cat. I ended up having a friend of mine weld it back on.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-13-2007, 04:26 PM
nova1313's Avatar
nova1313 nova1313 is offline
definitely the heat sheild on top of the cat. I had the same problem. It's freakin annoying. You can either redo the weld or tack it down with a clamp.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
nova1313's Avatar
tack it down with a clamp. I had to do that on mine. A weld broke of the heat shield over the exhaust pipe that is right below the fuel tank.
Old 07-13-2007, 04:37 PM
david-b's Avatar
Dave is THAT guy
But it was weird cause I put a C-Clamp on the cat itself and it stopped it. I'll have to check out the heat shield. All I did was look for contact between the exhaust and shield, not shield to car.
75 Monte Carlo
