Old 07-08-2007, 04:25 PM
nomi123 nomi123 is offline
Check engine light
Our 1997 Blazer has the check engine light on. We've checked and topped up all obvious fluid levels, engine runs great, no transmission shifting issues, back brakes need to be bled I think. Just did an oil change and put in a air filter (the previous owner didn't have one in for some reason...not sure how long it ran without it).
Any ideas on what may be causing this?
Old 07-08-2007, 04:31 PM
tiddy03 tiddy03 is offline
Re: Check engine light
check out the o2 sensors if not take it to advanced auto parts and they will hook up a computer to tell you what is wrong check engine light can be anything even your exaust
Old 07-09-2007, 10:09 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
The very first thing you need to do is get the codes and post them back here
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 07-09-2007, 11:00 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Was the light on before the air filter change?
MT
Old 07-12-2007, 04:37 PM
hakogen's Avatar
hakogen hakogen is offline
youre better off going to AZ than advance ;-D
however, you do need to get those fault codes.
2001 S10 2.2 NV1500
