AC not working
My A/C does not work
The relay is ok. The system has Refrigerant. I did notice the clutch does not kick in to turn over the compresor does this indicate the clutch is bad. Any help is appresiated! Thank you! |
Re: AC not working
ANy break in the clutch circuit/control can cause this: out of details about the car year, this www.avigex.ca/xport/accompressorcontrol.jpg
is a typical Pontiac schematic : you see it includes pressure switches , a relay, and authority from the ECM.... Since you say the relay is good, may be you could make a direct bypass from that point to see if corrent flows through compressor clutch coil...or simply test it with an ohmmeter.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
Re: AC not working
Check to make sure the low pressure sensor isn't damaged/disconnected. This will prevent the compressor from kicking on.
2000 Montana EXT- 116,000 Miles *SOLD!* 1999 Chevrolet Malibu 134,000 Miles 2001 Montana 96,000 miles |
