Old 11-03-2002, 11:00 PM
Racincc85's Avatar
Racincc85 Racincc85 is offline
Send a message via AIM to Racincc85
Subwoofers
I am looking to put a sub in my car. I don't know what brands of subs and amps are good and what ones are bad. I was wondering if anyone knew what brand(s) would be good for a decent quality system. I was looking in the range of 400-600 watts and either two 10's or one 12. I also don't want to spend over 400 bucks. Also, which is better, a bandpass box or a sealed box? If someone could help me out i'd really appreciate it.
Old 11-05-2002, 12:25 PM
lloyd_nickens's Avatar
lloyd_nickens lloyd_nickens is offline
Re: Subwoofers
I would recommend the diamond cm3 line.
"God Bless BASS, What Would We Do Without It?"
"If You Can Breathe, Turn The Music Up."
Old 11-09-2002, 01:58 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
there's a lot of good brands out there, kicker, JL audio, mtx, rockford fosgate, etc. You could definately find something for under $400 that would make you happy. Good amp 200, nice sub 125, that's only 325. About the box, the bandpass box will be louder, but the sealed box will have a little bit better sound quality. I don't think you'd even notice the difference in sound quality much at all, so I'd recommend a bandpass box for you, it would be much boomier.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 11-09-2002, 04:16 AM
DankiestStereo DankiestStereo is offline
are u spending up to 400$ on just the subs, or subs and amp???
and with the boxes, the bandpass is louder, but the bandpass is loud ina very narrow frequency range, which will make every bass note sound the same. ALso bandpasses color distortion, so you cant hear when your subs are being over driven. Unless you want an "overal" louder box, or want to hear everything sound the same, get a sealed box
I can Hook Up The Dank...... Stereo
Old 11-09-2002, 05:39 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
If you are building your own box then I recommend a simple sealed enclosure as there is a lot less you can fuck up.
Old 11-10-2002, 04:00 AM
hmmm
well if u want it to just bne really loud at certain frrrrequencies, then use a ported, call the comopany and ask them.
it all depends on what you want...
Old 11-20-2002, 10:02 AM
un4gvnbb's Avatar
un4gvnbb un4gvnbb is offline
what kind of car do you have?
if its a hatchback i would definatly recommend a seald box. if no openings to the trunk then i would recommend a bandpass.
JL's in my opinion are the best subs, especially for the money
Old 11-20-2002, 10:03 AM
un4gvnbb's Avatar
by the way does anyone know how to update your profiles???
Old 11-21-2002, 01:19 AM
just depends on what type of bass you want
ported= lowww bass
Old 12-24-2002, 08:39 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Ported (often) = LESS low bass ... the reason is that the speaker is unloaded below the tuning freq, which is usually around 35 Hz
to change your profile ... look at the top ofthe screen ... there is a link called "profile"
"but the bandpass is loud ina very narrow frequency range, which will make every bass note sound the same" .... not exactly correct - if the box is poorly made, it will greatly amplify a small band of bass frequencies, making it SOUND like your music has only that narrow band. It can't actually change the frequencies of the recorded music. It's commonly referred to as a "johnny-one-note" box
With all the bargains out there, you should certainly be able to find a good bass setup for $400.
Old 12-24-2002, 03:43 PM
yes a prtoed box will lose volume below the tuning frequency
but when i say more low bass, im talking about bass between 30-45 hertz
which is where boxes are always tuned to when ported, so witha ported you will be louder.
if you tune it to 40 hertz, the sealed will start being louder around high 20s maybe 28 hertz
Old 12-24-2002, 03:49 PM
Old 12-24-2002, 07:58 PM
Deakins's Avatar
Deakins Deakins is offline
Not only loose output, it will damage the sub.
The ringing of the division bell, have stopped...
AF User Guidelines
Old 01-20-2003, 08:02 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
the only way you'll damage the subwoofer is to play the frequencies below the tuning freq. a subsonic filter should help out.
I love them sub wufers
Old 01-21-2003, 09:39 AM
Deakins's Avatar
AF User Guidelines
