Old 07-08-2007, 01:40 PM
tiddy03 tiddy03 is offline
Exclamation need help 92 cavalier
drives fine until the motor has warmed up then when you come to a stop it shuts off and the only way to get it going again is either let it cool off or crank it up and put it in low gear what is causing this
Old 07-08-2007, 02:17 PM
Android_Gimpy6456's Avatar
Android_Gimpy6456 Android_Gimpy6456 is offline
Re: need help 92 cavalier
Sounds like it might be your TCC there should be a four pin connector in the front of your transmission. Mine is green in color. Try unpluging it and then go for a drive, sometimes they get boggered up for some reason I cant plug mine in. It will do the same thing.
There's nothing better than a one wheel peel, espcially when you peel the rubber right OFF.
Old 07-09-2007, 03:26 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
I hate the idiots who just say to unplug it. Its seriously a 15 minute fix, cost about $30, and will actually allow you to have a third gear. The above solution will prevent the final drive ratio. I've listed instructions and links to pictures before. Search.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
