Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-08-2007, 08:01 AM
dominoid8 dominoid8 is offline
Smile check engine light on 94 cavalier
I looked under my hood when i got home from work this morning when I knew something didn't sound right,and saw that my drive belt has about had it and its a cheap one that I bought and its just 3 months old and I drive 45 miles 1 way to work everyday. My check engine light has been coming on,i'm wondering if my drive belt was causing it,and if it was,a new belt should fix that problem. This time,i'm buying the best belt in autozone.
Old 07-08-2007, 11:03 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: check engine light on 94 cavalier
Its possible, though off-hand I couldn't tell you want sensor would trip it. You've got to replace the belt, obviously. So, replace it and see if the light goes away. If not, just do a search on how to jump the pins on the OBDI connector, and let us know what enginge codes you get.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 07-10-2007, 07:03 PM
I replaced the belt and even bought a 12oz can of carburator cleaner and cleaned the throttle body and it appears to be clean now from what I can tell. i use a screwdriver to hold the flapper thing open to clean it and as far as I can see inside it,its clean,i'm not sure about the internal workings though. Maybe you could tell me where I can go to get a throttle spacer installed.
Old 07-13-2007, 10:42 PM
Smile Re: check engine light on 94 cavalier
Can the map sensor cause the check engine light come on if its got a vacumm leak? I found the plastic line broke on the map sensor and repaired it with a small rubber hose,and I believe that may have been the problem and won't know for sure until i'm on the way to work tomorrow night. There is now a big difference in the vehicle's performance anyways. Someone please let me know if that is known to trigger the check engine light or not.
Old 01-25-2008, 10:33 PM
anomaly_va_1976 anomaly_va_1976 is offline
Yes, and it is a common problem.... Glad you found it
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
Old 01-25-2008, 11:14 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
anomaly_va_1976 please check your inbox for a PM. This thread is closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
