Old 07-07-2007, 11:21 PM
Velocity Stalks?
Trying to cook up ideas for velocity stalks for a project.
Any ideas/suggestions besides buying a set or fabricating my own on a lathe/mill?
I read somewhere about "eyelets" at the local scrapbook shop, but couldn't find the thread I read it in.
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 07-08-2007, 08:39 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Velocity Stalks?
Even with a lathe (this is actually something that can be done without a mill) it's not an easy straightforward thing to make. Making one is easy, but making 6 or 8 identical takes some thought and work.
Check out Stevenski's Super 7 build for an easy, great looking solution.
PHOTOBUCKET SUCKS
Old 07-08-2007, 09:24 AM
Happy Martian's Avatar
Happy Martian Happy Martian is offline
The items Stevenski used are uninsulated bootlace ferrules, and should be available from most electronics stores
Old 07-08-2007, 01:28 PM
cinqster's Avatar
cinqster cinqster is offline
I've had great success using just the taper tool from a car brake pipe flaring kit. I cut alloy tube overlength, tape the tool head to my vice jaws and gently squash the tube and taper piece together in the vice. If you make sure the tube and tool are dead square in the jaws and are very careful at applying pressure, very good results can be had. The other end of the tube tends to distort (hence it's left overlength until the flaring's done). Key to a good finish is to sand the tube end to be flared after cutting and then polish on a rag with Autoglym etc. This seems to let the tube slip over the tool better and not split. I can only get about a maximum 45 degree flare with the tool I have but these have been fine for the cars I've done. Big rolled flares (as on later Cossie DVA's/bikes etc.) are a no-no though!
If you can't get such a tool I reckon you could try brass countersunk woodscrews. Cut the screw say 5mm after the countersunk head and shoulder meet - the shoulder should guide it into the tube and onto the flare.
Good luck.
Old 07-08-2007, 09:48 PM
vintagethunder vintagethunder is offline
A guy I know came up with a system using aluminum tubing over a piece of bent piano wire chucked into a drill. He put oil on the piano wire and slid the piece of tubing up and down the piano wire with the drill on to work it into a flare. By doing it with a couple of steps he could even get it to flatten into a flange.
Old 07-09-2007, 03:00 PM
CADguy's Avatar
CADguy CADguy is offline
Do a search for "funnel" on this site and get some from Sakatsu.
http://www.stradasportsstore.com/
I used them and they look awesome.
Matt
Old 07-10-2007, 01:51 AM
Thanks for the posts.
Going to try the electrical terminals first (I even posted in the thread!!! hah!)
AF MODELING FAQ
Old 07-10-2007, 06:02 PM
cinqster's Avatar
Pah, far too easy!
Old 07-11-2007, 09:08 PM
Originally Posted by cinqster
Pah, far too easy!
Nice. Scratch built manifold?
AF MODELING FAQ
Old 07-16-2007, 04:19 PM
cinqster's Avatar
Cheers. Yes, it's one half of the trick Troy Trepanier Hilborn set-up. Still unfinished - as usual!
Old 07-16-2007, 04:37 PM
But why make do with plain metal stacks. Why not make them from carbon fibre ?
These are from an Aston Martin DBR9 V12 engine, photographed at a Prodrive Open Day over the weekend.
