Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 07-07-2007, 07:05 PM
suekpti suekpti is offline
96 Avenger stalls and won't start when hot
My daughter's 96 Avenger runs fine for about 20 minutes and then it stalls when slowing to a stop. Once it stalls, you can't start it again until it completely cools off. Then it starts up and runs fine. On one hot day, this happened three times. We took it to our garage and they replaced a clogged fuel filter thinking that it was the problems, but it still happened. WE checked the engine codes and we're getting a P0301. Any ideas??
Old 07-11-2007, 02:05 AM
danny87 danny87 is offline
Smile Re: 96 Avenger stalls and won't start when hot
try a tune up first cheap stuff first then the most $ later the cheap stuff will probly help that out dose it have A/C?
Old 07-14-2007, 09:02 AM
Yes, it has AC. We're replacing the ignition coild today to see if it helps. WE haven't driven it more than 20 minutes at a time, so it hasn't gotten warm enough to stall lately.
Old 07-20-2007, 11:12 PM
twistedtech twistedtech is offline
I can only asume that your tech has a good scanner like a 2500a so he can watch the crank sensor. I bet it drops out when hot.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 07-27-2007, 07:08 PM
Our 96 Avenger stalled again two days ago when it was really hot outside. She drove it for about a half hour, and it died when she was slowing at an intersection. It wouldn't start again for about an hour and a half. Then it started and she drove it home without stopping much. We're baffled as far as what to replace now. We've noticed that it leaks coolant slowly. We have to add some every few days.
There are so many sensors on these Avengers, that one of them is triggering the computer to shut the engine down when it's hot. We tried to test the map sensor and it was getting power okay. We didn't test it with the engine running though.
Old 07-28-2007, 06:22 AM
After the car stalls and won't start (until it cools), it does crank over, it just doesn't start. Could it still be the crank sensor?
Old 08-14-2007, 09:44 PM
terry LAMB terry LAMB is offline
I am having the same problem with my 96.What I have found is when this happens.You can unplug the coolent sensor for the fan just under the radiator cap and the car will start and run.that way the computer isnt shuting down the car because it doesnt know its hot.When I figure out whats wrong with mine if I do.lol.I will post it and send to you also.You do the same.
Old 08-17-2007, 05:36 AM
We'll try that next time it stalls. Then we have to figure out why it gets so hot. We're going to replace the water pump next. And the timing belt while he has it apart. Now that we took the car off the road, we have time to figure it out.
Old 07-09-2012, 11:39 AM
ShadeTreeJack ShadeTreeJack is offline
"When I figure out whats wrong with mine if I do.lol.I will post it "...hello Terri? Suekpti?? what was it? I have money on twistedtech and the crank sensor - had that 3 times on my GM products. please update as it will help others solve their issues
Old 06-06-2013, 10:04 AM
Rexcon Rexcon is offline
There are such a large number of sensors on these avengers that one of them is triggering the workstation to close the motor down when its smoking.
We tried to test the guide sensor and it was getting force
used forklifts for sale
