check engine light on--P0171 & P1130 codes
i got a camry 98 4cyl have
this code P0171 System to lean (bank1) and P1130 Manufacturer controlled fuel and air metering what could be the problems? hope you guys can help me out, thnx in advance! already changed all vaccum hoses, intake pipe hose fuel filter, gas cap. |
Re: check engine light on--P0171 & P1130 codes
http://www.obd-codes.com/trouble_cod...gen-sensor.php
This is from the FAQs thread at the top of the forum: P0171 System too Lean (Bank 1) Possible Problems When the air fuel ratio feedback is stable after engine warming up, the fuel trim is considerably in error on the LEAN side (2 trip detection logic) Air intake hose loose Fuel line pressure low (may be from running out of gas) Injector blockage HO2 sensor malfuction MAF meter malfunction Engine coolant temperature sensor malfunction Clean MAF meter with electronic circuit cleaner<= most likely Fix vacuum/intake leak downstream of MAF meter Inspect fuel lines for cracks, leaks, or pinches Replace fuel filter Check fuel pressure at the fuel rail Check output of HO2 sensor Check injector performance Check ECT sensor Results of a history search using search function upper right: http://www.automotiveforums.com/vbul...ht=camry+P1130 http://www.automotiveforums.com/vbul...ht=camry+P1130 http://www.automotiveforums.com/vbul...ht=camry+P1130
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
Instead of the MAF meter, it may be a MAP (manifold absolute pressure) sensor (in your engine)
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
i have checked my oil its lacking half in the deepstick. will that also make my check engine light "ON"?
If you mean the oil is a half-quart low, then no, it won't cause your check engine light to come on.
