Old 07-07-2007, 08:16 AM
BIGPETEG24 BIGPETEG24 is offline
car won't turn off
95 escort wont' turn off keeps running help
Old 07-07-2007, 09:12 AM
Selectron Selectron is offline
Re: car won't turn off
I'd remove the connector from the battery negative terminal. I'd leave it off until I located the fault, otherwise it will flatten the battery. Ignition switch would be the prime suspect, or it could be a short-circuit in the wiring harness.
Old 10-25-2007, 02:09 PM
shermancelmare shermancelmare is offline
Gosh, that is the first time I have ever heard of such thing! You basically need to reverse-jump start it.
I agree, faulty ignition would be my first idea.
Old 10-26-2007, 12:02 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Ditto... unplug the ignition wiring from the switch and use some jumpers to test the circuits.
