Go Back   Automotive Forums Car Chat > Fabrication & Tools > General Tools
General Tools Discussions about tools - there are thousands of various tools you can use to work on your car. Do you have the right one for the job?
Old 07-06-2007, 10:11 PM
Bob1942 Bob1942 is offline
Removing hard to remove bushings
I was trying to get a bushing out of an oil pump last week it was really in there ! Somewhere I had heard about threading the bushing with a tap ,screwing in a bolt and driving it all out with a punch or rod ... Well I tapped the bushing with a big tap I had then I found a bolt that fit, screwed it in and drove the bushing right out with a long punch ! SO EASY ! Took about 5 minutes I just thought I would pass this on and save some other guy a lot of trouble.. BOB
Old 08-12-2007, 10:49 AM
taillight taillight is offline
Re: Removing hard to remove bushings
Another good way is to use a cape chisel and cut a grove in the bushing. The bushing will fall right out.
Old 10-02-2007, 12:59 PM
Dave Hughes's Avatar
Dave Hughes Dave Hughes is offline
Or you could use a Oil Pump Bushing Remover
May not be worth the cost if you're only doing it one though.
Old 11-01-2008, 04:36 PM
rjfranken rjfranken is offline
same for those vw starter bushings 1/2 inch tap thread ed in and it backs the bushing out.
