Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 07-06-2007, 09:06 PM
s_k_b s_k_b is offline
2005 Malibu Maxx Rear Brake replacement
Looking for advice. I'm trying to replace the rear disk brakes pads on a 2005 Malibu Maxx (6 Cyl.). Calipers are the "twist" type and I am able to compress the caliper all the way in using the "cube tool" on a 3/8" ratchet. The problem is that I can't get enough clearance on the outer pad to re-install the caliper.
Here's the procedure I'm following:
Removal:
- the obvious: jack rear wheel, block it, remove tire, etc
- remove to lower 14mm bolt from holding the caliper
- loosen the top 14mm bolt holding the caliper
- Observation: the top mount is rigid and does not move in/out as opposed to the bottom caliper mount which moves in/out to allow for brake pad wear
- rotate the caliper upwards all the way ensuring that you don't kink the brake hose and/or parking brake cable (at rear of caliper)
- using cube tool, twist in piston clockwise all the way in.
- remove pads and clips
Re-installation:
- install clips
- install pads; with the wear gauge on the interior
- attempt to lower the caliper (which is still bolted to the upper mount).
At this point, there is sufficient clearance at the inner pad (caliper piston), however there is missing ~ 1/8"n the outer side. The caliper will not go into place.
The pads I purchased are Monroe from Canadian Tire. I called to double check that I have the correct set.
So ... I'm wondering if
1) the pads are non-compatible or incorrect or
2) the rigid mount (see observation) is somehow seazed and not allowing the caliper to move
Any advice is much appreciated
Old 07-08-2007, 07:03 PM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Re: 2005 Malibu Maxx Rear Brake replacement
If only i had a picture of what your saying
opcorn:
