Old 07-06-2007, 08:18 PM
danols15 danols15 is offline
Cruise Control Brake Switch?
Hello, My Cruise just started not shutting off when the brakes where depressed unless you slam them hard, I think it would be the switch on the brakes since the switch still disengages it like it normally should.
Any suggestions are great!!!
-dan
Old 07-07-2007, 09:32 AM
scoobytuff scoobytuff is offline
Re: Cruise Control Brake Switch?
Sounds like you are on the right track. I imagine the contacts in t he brake switch are getting worn out. It's possible you could clean up the switch and buy yourself some time, that's only if you care to go to the trouble. I really think those switches are pretty inexpensive.
Old 07-08-2007, 10:13 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cruise control diagram for 2001 MY:
http://www.larrynova.com/Jeep/00/VSS_and_ABS.pdf
Test with a voltmeter. Maybe it needs adjusting also.
