Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-06-2007, 07:22 PM
mike561 mike561 is offline
tire losing air no hole though...
I drove my car over to get the tire filled a bit because it was kind of low, NOT completely flat though. as i filled it to the correct presssure, well by eye compareable to the others, i herd air escaping from around where the tire meets the rim on the outside, and the stem would let air out if i moved the stem slightly too, i know the stem can be replaced though. whats the deal, hope its not an issue with the rim itself. btw, when i had the rims put on i remember them saying one was bent, but it still held air til now and diddnt look bent upon visual inspection, but showed it was slightly on the balancer, and i dont even know if it was the same rim they were talking about.
2006 Chevy Cobalt LS
Old 07-06-2007, 08:21 PM
Re: tire losing air no hole though...
well it doesnt seem to be loosing air at the moment but ill keep anyone updated whos interested
Old 07-06-2007, 08:27 PM
stockblackxj stockblackxj is offline
Ive had a few tires lose air with aluminum rims. when i changed my last set i used a generous amount off a "goop" they had where i installed them. kind of a black goo , sticky glue type thing. this prevented any leaks for me.
Old 07-06-2007, 10:05 PM
i probably should have had that stuff put on
Old 07-06-2007, 10:27 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I've had issues with the bead deteriorating on the tire and as a result the tire will lose air where it meets the rim. If you have the tire separated from the rim do a visual check of the mating surface where the tire meets the rim.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 07-06-2007, 10:41 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Sometimes, moisture in the air within the tire will cause the wheel to corrode (rust) in the area of the tire bead as well. I've found that a can of fix-a-flat can do a good job of sealing these or other bead leaks without needing to go see a tire specialist. The downside is that if you don't follow the instructions on the can to the letter, you can throw a tire off balance and set up a vibration.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-07-2007, 12:45 AM
yeah i think ill just have it checked out when i get new tires, i think its almost time soon anyway. the tires definetly look like they've seen better days
Old 07-15-2007, 10:43 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Could just be a bad valve stem, see those at my shop all of the time. If it is you have to take the tire off so replacing them could be a possable choice anyway.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 07-16-2007, 01:51 PM
im probably going to have them replace all the valve stems as well, because they came with the used rims so who knows how old they are or how much longer they will last.
