Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-06-2007, 01:52 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
Inst. Cluster issues
So recently I've replaced my Alternator, and battery. I just got a full tank of gas. and the gas gauge only reads just over three quarters of a tank, and im 100% sure i got a complete full tank of gas, and i dont think any of the other gauges are reading right, but i cant be sure of that. I dont know if the sending unit is to blame or if anything else is messed up. any info would be great
P.S. I drive a 1993 Olds Cutlass Supreme SL with the 3.1L V6, and its the analog Inst. Cluster. NOT DIGITAL
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
Old 07-11-2007, 06:37 PM
Ian Szgatti's Avatar
Ian Szgatti Ian Szgatti is offline
Re: Inst. Cluster issues
what guages does your cluster have, and why cant you tell if they arent accurate?
Old 07-11-2007, 06:39 PM
XGamesJ6's Avatar
i have the Oil pressure, Collant Temp, Mph, RPM, Voltage, and gas, and well the voltage always reads below 13, like 12.5 or something. and my multi-meter reads 13.8. so im sure that gauge isnt right. the gas gauge only went up to 3 quarters after i got a full tank, oil pressure i could have sworn used to read a little bit higher, but i cant be 100% sure. and the coolant temp just always moves around, but it never peaks really high so i dont worry about that.
Old 07-16-2007, 11:45 AM
3100MPFI 3100MPFI is offline
Send a message via AIM to 3100MPFI Send a message via MSN to 3100MPFI
sounds like the float in the tank is binding up. Common problem for the W-bodies.
I don't know about your cluster, but the 1992 cluster in my 1988 is VERY accurate. You could have a cluster problem, but I don't know how to go about testing for a faulty cluster at this time.
I would keep an eye on the guage and see if it goes down at all. If it does go down, then it sounds like your float is binding and not going all the way up. If it does not move at all, then it is stuck.
Either way, you have to drop the gas tank to fix it, so you might want to go ahead and invest in a new pump, strainer, and pulsator while you are there.
Old 07-28-2007, 11:14 AM
XGamesJ6's Avatar
i found the problem, a spider got in, and made webs that i couldnt see over the gauges, took it all apart, cleaned it out, vaccuum and such, all is good now, everything works, even better then before. so no worries
