Old 07-06-2007, 01:56 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
rubbing brake?
problem just started two or three days ago. when i start driving i hear a squeak, when i apply the brakes a bit it goes away. when i apply the handbrake (lightly, not locking up the rear tires) it doesn't make a difference, so it's my front brakes. I'm thinking my brakes are rubbing, but i don't know if it's a problem that i should have looked at or if it's an easy fix that i can do at home. is it an urgent problem?
the car's a red 92 accord ex.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 07-07-2007, 01:33 AM
UncleBob UncleBob is offline
AF -Advisor
Re: rubbing brake?
sounds like you're on the squealers....they make noise to warn you that its time to do the brakes, before you go metal-to-metal
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 07-07-2007, 10:16 AM
Re: rubbing brake?
i thought those were only supposed to make noise when you actualy apply the brake
Old 07-07-2007, 12:22 PM
AF -Advisor
Re: rubbing brake?
no, they can do it either way. Depends whether the brake pad is pushed back when the brakes are released or not
The important thing is, the noise changes when you hit the brakes
Old 07-11-2007, 07:03 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: rubbing brake?
All rotors have runout so you will hear the noise without applying the brake. Depending on how far the sensors are contacting the rotor, the noise might lessen with the brakes applied.
As a very short term fix, I've bent the sensors out of the way until I could get around to changing the pads. But you have to crawl under the car and probably remove the wheels, who works on their cars these days?
Bob
Old 07-11-2007, 07:48 AM
Re: rubbing brake?
haha yeah, i would like to do my brakes myself but since it's a honda i don't want to put myself through it. i worked at a shop and apparently they're some of the worst brakes to change. i guess i'll just take it in soon
Old 07-11-2007, 11:17 PM
AF -Advisor
Re: rubbing brake?
cutting the rotors are a pain, but if you're just doing a "pad slap" there's nothing difficult about a honda
