Old 07-06-2007, 12:18 PM
tspeck007 tspeck007 is offline
Auto Trans Fluid Change 90,000
I have a Pontiac with 90,000 miles and I do not know if the transmission fluid has been changed in the past.
I've heard that it may not be a good idea to change it now as changing may cause further damage. Is this a wives tale?
What should I do.
Transmission/car works fine. No sign of problems.
Much thanks in advance.
Old 07-06-2007, 01:26 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: Auto Trans Fluid Change 90,000
Depends on the year. Newer cars with Dextron/Mercon 4 fluid are considered "fill for life" and can be left alone, older dextron/mercon 2 or 3 fluids should be changed. The owners manual will tell you what fluid was used at the factory.
In general, cars that have never had a FLUSH (or history is unknown) should only be flushed if under 100,000 miles. Flushes are done on a professional machine that uses new clean fluid mixed with special detergents to wash away built up gunk. The detergent rich fluid is then pushed out and replaced with regular fluid. If this is done at 100,000 + miles, it tends to release big deposits of crap stuck in odd corners of the transmission, sometimes causing them to re-deposit in a bad spot in the valve body, leading to premature failure.
A simple pan drop 'n' drain with a replaement filter isn't as good as a flush but is always safe - even if service has been neglected in the past.
The ultimate cleaning involves doing a flush, then dropping the pan and replacing the filter. It's pretty expensive due to the huge amount of fluid that gets thrown away, but will extend transmission life.
I guess the best way to decide is to take out the dipstick and let a few drops of fluid fall on a white sheet of paper. If the fluid is:
Bright neon red: just leave it alone
Dark red: have it flushed by a shop, opting for a flush and filter is worth it
Brownish red: change it, replace the filter. DO NOT FLUSH
Brown and smells like something died in it: Don't waste your time. Get a rebuild, or start car shopping immediatly.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 07-07-2007, 12:37 AM
UncleBob UncleBob is offline
AF -Advisor
this is a common belief, that if you go beyond a certain time frame, that you're better off leaving it alone.
There is a small amount of truth to this, which is, if a tranny is DAMAGED, flushing it might bring a problem to the front that wasn't obvious before.
But really, the tranny is already in trouble at that point. Purposely NOT servicing it isn't really an effective way of solving the problem, unless you want to sell it anyway.
If you care about the car, get the system flushed. If you don't care about the car, sell it.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
