Go Back   Automotive Forums Car Chat > Plymouth > Acclaim
Old 07-06-2007, 12:31 PM
danthesk8er danthesk8er is offline
Cooling system overheating.
Hello,
I posted about this problem a while ago and fixed what was wrong with it then. Whats happening is anytime I'm stopped in traffic, going through a drive through, pretty much anytime the car is idling it goes past the middle of the hot and cold then the fan on the car runs for about a minute cooling back down. I know this isn't normal operation. I have already replaced the head gasket, water pump, the thermostat, radiator cap, and the temperature sensor. I don't think a bubble is stuck in the system because i have run the car with the radiator cap off multiple times and burped the system. It could be possible there is a bubble in there somewhere but not likely, and if there is a bubble I can't think of any other way to get it out. I checked the coolant pH and it is right on. I can't think of anything else to do. I have flushed the system 2x now and still no improvements. It used to work just fine before my head gasket wore out and I replaced it. Any suggestions would be helpful.
Thanks for your time.
Old 07-07-2007, 06:07 PM
KManiac's Avatar
KManiac KManiac is offline
Re: Cooling system overheating.
What you have described: Idling stationary, your temp gauge swings to about 2/3rd's to H, the fans start and run for a minute, the temp gauge swings back to 1/3rd to H and shut off.
Situation: NORMAL! My Shadow has done the same thing for over 14 years!
Don't start worrying until the gauges pegs out at full H and stays there.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 07-08-2007, 05:14 PM
Ok thanks for the reply. I wasn't sure because before all these problems I never payed attention to the temp gauge so I must not have realized this is normal. Thanks for you're help. It's always greatly appreciated.
