Old 07-05-2007, 04:01 PM
PlayStation3 PlayStation3 is offline
Laminating enclosure
hi, i am thinking about laminating the front of my enclosure and i was wondering how hard would it be to laminate it. i never tired it before.
Old 07-05-2007, 10:47 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Laminating enclosure
laminate ? like putting a sheet of something over the top of the wood ?
Old 07-06-2007, 12:34 AM
yea i saw one it had black carpet and the front had black laminate on it.
http://www.woodlawncabinetry.com/Res...tom_Boxes.html
bottom of the page. and if i don't laminate it then i am going to do a color changing paint for the front.
Old 07-07-2007, 09:22 AM
Audio Guy
that could look nice
Old 07-07-2007, 09:52 AM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
What they're talking about for that box isn't what most people think about when you talk laminating. Normal laminating is like when you laminate a card with two pieces of plastic to protect it from liquids and such. I believe the laminate that they are talking about is the kind of laminated wood like you would buy for kitchen counter tops where it's particle board with a thin sheet of pressed wood painted or stained a certain color glued down to the particle board. I think if you're wanting the shiny look then it would probably be better to fiberglass the front of the box and paint it as after time and the extreme heat inside a vehicle during summer days would eventually make the glue loosen up and cause problems.
Old 07-07-2007, 12:31 PM
yea but it also would be held on to the box by the 8 or so screws for the each sub. but the fiberglass thing might work and then just get a flat black or what ever to get the same effect because fiberglass can make it look really shiny,
Old 07-07-2007, 11:44 PM
Audio Guy
there are high temp glues for that
Old 07-08-2007, 12:03 AM
which would you think would be easyer and still look good.
Old 07-08-2007, 09:12 AM
Audio Guy
sanding fiberglass smooth enough to make it look the same as the laminate is a lot of work, cutting the laminate straight and getting it glued on just right may be a bit difficult too
